Reply To: Need help with Blender settings
Forum Archive Need help with Blender settings Reply To: Need help with Blender settings
#45236
John Sanderson
    @dragonice69 if anything is in the compositor or VSE, it can override the render output in the image editor.  If it looks like your image is rendering normally and then it  changes just as the render finishes, this is probably the culprit.  You can disable them under “Post Processing” in the render panel. If it’s rendering the old image from the get go, then something else is going on.  I would probably need to look at the .blend to venture any further guesses.
