So, it looks like either the top (in Z-direction) Vertices are misaligned, or the bottom ones. If that is the case, you can Delete the top or bottom (which ever is wrong), just like I mentioned above.
If some of the wrong Vertices are in the top and some in the bottom, the best thing would be to start over, which is probably the best anyway.
