Reply To: My bubble doesn’t resemble yours at all
Forum Archive My bubble doesn’t resemble yours at all Reply To: My bubble doesn’t resemble yours at all
#85978
Paul Caggegi
    the gradient material is perhaps a little too tight, yes. If you’ve created that texture on its own layer, go into edit mode, select the shape with the radial gradient on it, and use the transform/rotate/scale tool to scale it up a little. I think this should fix the issue quickly.
