Hi Ingrid @Fide ,
That should be possible (if the Poses are not too extreme). Make sure the Armature Modifier is above the Multires Modifier.
It ‘ll probably work best when you first set up the Armature and Bone Weights, before you start sculpting, but maybe it might also be possible to add the Armature after Sculpting (still, put the Armature Modifier above the Multires for best results).
