There is no solution to this problem if you ask me. An image will always vary from monitor to monitor, unless everyone in the world sync up and everyone uses exactly the same brand of monitor and the same settings. There are software that will calibrate you monitor for you, but then everyone else will have it different from you nonetheless. So just don’t worry, you work how things look on your monitor and hopefully it will look good on other people’s monitors.
