Reply To: mirror poses / paste flipped issue in 2.93.4
Forum Archive mirror poses / paste flipped issue in 2.93.4 Reply To: mirror poses / paste flipped issue in 2.93.4
#71245
Wayne Dixon
    Hi Grey,
    I’m not following 100% with the process that is producing this issue – if you could post a video or some images that would be most helpful.
    I can hazard a guess though, just check that his starting position is actually the same as in the video.  It possible that you have rotated the controls rather than starting with the object or the root control pointing in the correct direction.
    That is likely to give you unwanted rotations in the “default” position that will also be mirrored.  (ie – if it’s is at -90 degrees it will flip to +90)
    Hope that helps you solve it – but if it doesn’t, please post a video.  A video says thousand words a second…well that’s what they say anyway.
