@beefkeef well, I have worked as an illustrator for awhile + I draw pretty often. So there are always a lot of sketches/ideas floating around the table or in my mind) And I write too. As I have mentioned before — I’ve got a book on its way + around 25 scripts. So inspiration is basically everywhere. Right now I’m trying to produce these scripts but I’ve hit a wall. Not just in a technical sense but more of a scaling type I suppose. It is quite like the “Hello world” Java thing if you know what I mean — when you got your basics covered and then there is a whole world to explore. And a huge gap between “Hello world” and the actual world.
So this is just an attempt to move my boundaries a little further and step out of the comfort zone. Sorta the same thing I did with that Reitwagen model after the donut course) It is much easier to work on anything after that.
