here’s the breakdown of the scene now that i found the blend file again, what i also found that i had recorded the design session of 5 hours, so i’ll add timelapse here thats sped up 5 times .
first the wormhole scene, and i used the base from Gleb Alexandrov’s wormhole tutorial, so if you want to look the materials just goto Gleb’s channel and look it up, actually you should go there anyway and watch everything. guy is amazing. 🙂
so back to scene, the big sphere around is the world, uv-unwrapped and has the bottom left procedural texture on it which i did before, in hindsight, could propably use the same material i used to make the texture in the sphere directly.
then you have the smaller sphere that acts like the wormhole, trick here is to actually take the camera inside that sphere and also the sub is inside, that way you get all weird stuff going on with the wormhole material. tricky part was to angle the camera to get what i wanted at that time. and then you get the reflections going on forever.
and then there is the matcap render on bottom right just to show how simple it is without the effect.
and then here’s just clay render of the sub
and the promised timelapse of the modeling sub. it took me roughly 5 hours to make, mainly due to thinking design choices on the fly. references it took from various nautical vessels from google to drive inspiration from.
https://youtu.be/birkq15KGpM
