hi,
question 2 up
What version of blender are you using? The. tutorial uses 2.78, when I used 2.9, it didn’t. work this way and I had to copy the flipped to the ik.L. The important thing was to learn to copy the animation to the other side, saves you the time of having to animate both legs. It. sounds like you understand this and it looks like it is working right at the end of https://screenrec.com/share/gt9jMTbnWk, good job.
question 1 up
After you copied all the animation to the left foot (toe, heel, Ik, and pivot) , did you do the part (about 3:22 in the. video). where he copies all the animation on the left foot and then offsets it and delete the stuff on the ends. I think you are off here. For example when you are in the first pass position the left. foot isn’t in the correct position. Watch the above mentioned part of the video to make sure you are doing that right. You can tell it is right if the first C position looks correct after you do the -1.3/2. I know it is frustrating, but you will get it. You are making progress. Good luck.
