Reply To: Loop cut problem
Forum Archive Loop cut problem Reply To: Loop cut problem
#78838
    Ah, right!
    I never use the Active Tools. That is indeed the problem.
    Apparently, with the Active Tool you can set the number of cuts in the top left of your 3D View. Or change the number with F9 after making a cut (only affects the last one).
