Reply To: Linked Objects: What is the difference between “Make Proxy” and “Make Library Override”?
Forum Archive Linked Objects: What is the difference between “Make Proxy” and “Make Library Override”? Reply To: Linked Objects: What is the difference between “Make Proxy” and “Make Library Override”?
#69563
Wayne Dixon
    I have no idea how the technical aspects work.  But essentially you have a link to the original data (collections and all).
    An “Override” is a recorded change to that linked data.  You can see what overrides you have in your file and what they are connected to in the outliner (you can change it to display the data in the file)
