Reply To: Leg skin not moving with body
Forum Archive Leg skin not moving with body Reply To: Leg skin not moving with body
#61007
Wayne Dixon
    This looks like double transformation David.
    There are many possible causes so I don’t know the exact solution but essentially the verts are being transformed twice.
    You can check that you only have 1 armature modifier and also check that parenting.
    If the legs are parented to the body and also has a armature modifier, the parent is being transformed and then the verts are being transformed by the armature.  (hope that makes sense)
    I think if you parented the leg mesh to the armature and not the body this will be resolved.
