Reply To: Leg IK Messes Up Rig When Connected
Forum Archive Leg IK Messes Up Rig When Connected Reply To: Leg IK Messes Up Rig When Connected
#52606
Wayne Dixon
    Most likely your IK chain length will be set to 0 (this is the default setting) you probably want it to be 2 (or however many bones are in your chain)
    When it is at zero it will run all the way up from child to parent until it can’t go any further (which is probably your root bone)
    So it screwing everything up.
    Also I can see you have 3 broken drivers in your driver editor there.  You might want to look at why they are broken and then update after fixing it. (that’s the red lines under your drivers)
