Reply To: Left and Right Move reversed
Forum Archive Left and Right Move reversed Reply To: Left and Right Move reversed
#29190
Jonathan Gonzalez
    For the rocket used in the course, the window is actually a separate piece so the easiest solution is to make the window a child of the fuselage or something else and then you can rotate them together while keeping the same offset. Eventually all the mesh objects will be a child of another so you can do that as well.
