Reply To: Layout Separator does let you dictate a larger gap
Forum Archive Layout Separator does let you dictate a larger gap Reply To: Layout Separator does let you dictate a larger gap
#100330
Dwayne Savage
    Just a note: if you use column(align=True) the factor doesn’t work unless it’s high enough and that depends on your current resolution. Greater than 1.6 on a 1920×1080 display resolution if I remember correctly.
