Reply To: Knife tool
Forum Archive Knife tool Reply To: Knife tool
#87794
Leo
    if you use the knife tool, you can cut through the entire mesh with the c key. For example, if you are in the top view of a cube, you can cut not only the top side face but also the bottom side face or completely through it.
    Then you only need to separate the cut faces with the P key and you can then move them separately
