Reply To: Keyframes not showing up in dope sheet when object is copied
Forum Archive Keyframes not showing up in dope sheet when object is copied Reply To: Keyframes not showing up in dope sheet when object is copied
#50892
Joey Burrow
    Hi Wayne, Thanks or explaining it but I might totally be misunderstanding. I just tried selecting the animation data block but didn’t see anything to select in the data block. I also tried to append the  scene but nothing showed up as being copied over in the the new file.  Animated data I uploaded the file I am trying to copy from. I’m using 2.79b.
