A little update on this guy!
I’ve painted some colours onto his face and tried to capture the redness on his cheeks, nose and ears.
I didn’t do too much to the hair apart from colour it and added some AO. Also played around with the roughness here to add a little more interest.
Made a quick pass on the bowl and contents, I’ll come back and add something here – maybe it needs a bit more dirt or something to roughen it up as it’s quite clean.
I worked on his shoes a too – I tried to keep it quite simple and to the artwork style, I’m quite happy with the way they are looking.
I spotted a couple of problems with my UV’s 👀 One is on the underside of the sole of the shoe, there’s a tiny gap showing but I’m probably just going to ignore that given where it is! The other is on his pants – that shape is actually the pocket from the rear – how did I do that? 😅
So I might go back and rebake that texture set, or……. now that I look at it – I could use it to my advantage and turn it into a patch, as I do see that in some of Kjell’s art – will need to think about it.
