Reply To: Jonathan’s Polybook
Forum Archive Jonathan’s Polybook Reply To: Jonathan’s Polybook
#93487
    HI Florian,
    You can simple increase the Merge Distance in the Adjust Last Operation Panel, (or with F9):
    (And there is also a Modifier that you can use: Add Modifier > Generate > Weld, but be aware, that it has a larger default Merge Distance of 1 mm.)
