Reply To: I’ve been seeing this weird control system, what is it?
Forum Archive I’ve been seeing this weird control system, what is it? Reply To: I’ve been seeing this weird control system, what is it?
#74076
Wayne Dixon
    They are called ‘Joystick’ controls – well that’s what I know it as but it probably has other names too.
    Basically it’s like a joystick.  You move this thing here, and that thing over there does something.
    There’s no coding – it’s drivers hooked up to fire when a control is moved in a certain direction.  That’s if the mesh is using shape keys.
    If it’s using bones, then it would most likely be done with action constraints (ie – play an action when a control translates this way) but it could also be done with other constraints (depends on the needs)
    You can have a look at the 2D baker rig in the lip sync course to see how this works – but there’s no videos on how to build it.
    Essentially I am just driving the visibility of the mouth shape based on the location of the control.
    https://cgcookie.com/courses/demystifying-lip-sync-animation-in-blender
    hope that helps.
