Reply To: issue with the material around the cutout in the top
Forum Archive issue with the material around the cutout in the top Reply To: issue with the material around the cutout in the top
#51935
    @sheila5 Ah I see. That’s actually the texture used to rough up the edges of the material. It uses the pointiness attribute of geometry node to determine a factor for the texture to take effect. To fix the extreme effect around the cutouts you can try dialing down the pointiness color ramp.
