Reply To: Issue with smoothing.
Forum Archive Issue with smoothing. Reply To: Issue with smoothing.
#71285
Joshua Gardner
    Thank you for the Mask Overlay setting. That did the trick. I did not know that was there. In the video it shows only mask the area, pull out the fins, Remesh with .02 voxels, and with the grab brush morph to wanted style and hold shift to Smooth. The video smoothing barely removes topology but every time I try it its removing or shrinking the are drastically. If there isnt enough Topology after the remesh then the voxel size could be wrong. Still really new to this so trying to figure out if i did something different.
