Reply To: Is this topo acceptable?
Forum Archive Is this topo acceptable? Reply To: Is this topo acceptable?
#98859
    Oh,
    I didn’t think about Creasing those Edges before the Subdiv. That’s clever.
    Overall, this is an excellent workflow! Very elegant.
    The Extrusion on X is okay, you could also Scale a Plane (in Edit Mode) time 3 on the X-Axis and times 4 on the Y and then CTRL+R, to get the 12 squares.
    At 1:12, they use the Loop Tools Addon > Space. Very nice! Alternatively, you could Delete the vertical Edge Loop and CTRL+R to Add a new one, that would give the same result, only then you could simply Scroll up to get the correct amount.
    And Omar is good, as far as I know.
