Reply To: is this consider to be bad practice?
Forum Archive is this consider to be bad practice? Reply To: is this consider to be bad practice?
#97248
Deb kanta Guin
    Okay Martin and Omar, thanks a lot guys.
    One thing I realized is that I could’ve made the extrude part from the base that connects to the round dial without using Boolean. I could’ve just added more edge loops in that area  to get a smoother rounded shape  when using loop tools to create a circle so it matches better with the other objects. Then inset and extrude — no Boolean needed there. But I’m not sure, even with subdiv it might still look a bit blocky.
    For the dial pad though, I used Boolean to cut the holes. Could I achieve those without Boolean? Is there another way?
