Reply To: Is there better methods for selecting faces when select “Link” or “Paint” do not work well ?
Forum Archive Is there better methods for selecting faces when select “Link” or “Paint” do not work well ? Reply To: Is there better methods for selecting faces when select “Link” or “Paint” do not work well ?
#87676
Leo
    I don’t know if it helps but i came across the function “select loop inner region” and had to think about your problem. If you can select the edges of your mesh (eyebrows), you could also use the function “Select Loop inner Region” via SELECT -> SELECT LOOP -> SELECT LOOP INNER REGION. then all faces in the edge loop are selected. Maybe it doesn’t help here but elsewhere
