Reply To: Is there a way to point an object at something without using constraints?
Forum Archive Is there a way to point an object at something without using constraints? Reply To: Is there a way to point an object at something without using constraints?
#27576
Alexander Tokarev
    If you want to keep the transformation after the constraint is removed:
    –  select the object with a constraint,
    – press Ctrl A and select ‘Apply > Visual Transform’.
    – remove the constraint.
