Reply To: Is there a way to add x amount of frames (e.g. 50) by typing 50, instead of manually dragging a group of key frames along the timeline to get such a result?
Forum Archive Is there a way to add x amount of frames (e.g. 50) by typing 50, instead of manually dragging a group of key frames along the timeline to get such a result? Reply To: Is there a way to add x amount of frames (e.g. 50) by typing 50, instead of manually dragging a group of key frames along the timeline to get such a result?
#75912
Wayne Dixon
    Like Omar said, you can select the keys, active grab (G) and then type the number.
    You can also use the “Extend” operator which is more flexible.
    You can have multiple keys selected and then press E with your mouse on either side of the playhead and it will only affect the selected keys on that side.  This means less selecting/deselecting
