Reply To: Is there a shortcut to straightening edge loops along the normal’s/local’s xyz axis?
Forum Archive Is there a shortcut to straightening edge loops along the normal’s/local’s xyz axis? Reply To: Is there a shortcut to straightening edge loops along the normal’s/local’s xyz axis?
#97944
    Oh, maybe you mean straighten Edge Loops in the direction of a specific Edge.
    That could be done by Selecting that specific Edge and then click on the plus in the Transform Orientations to make a Custom Transform Orientation:
    Then you can Select the Edge Loop that you want to straighten and Scale: S, SHIFT Y, 0.
