Reply To: Is there a shortcut to straightening edge loops along the normal’s/local’s xyz axis?
Forum Archive Is there a shortcut to straightening edge loops along the normal’s/local’s xyz axis? Reply To: Is there a shortcut to straightening edge loops along the normal’s/local’s xyz axis?
#97943
    HI Kimberly,
    I don’t know what you want to do exactly (there is no general solution, but there might be an easy way to do what you want).
    Setting the Transform Orientation to Normal, takes the Average Normal of your Selection. That is why it most likely won’t work as you would like.
