Reply To: Is there a hotkey to see stretching in the UV editor?
Forum Archive Is there a hotkey to see stretching in the UV editor? Reply To: Is there a hotkey to see stretching in the UV editor?
#83630
Dwayne Savage
    Yeah, I always forget about the quick favorites too. I only remember it because @spikeyxxx  mentioned it in your post about the underscored letter shortcuts. I use to use those. I still fine myself hitting shift+a then hitting tt for image texture.
    Just did some looking around. You can create hot keys for both options if you want. Right click then click assign shortcut. Alt+d, and Shift+alt+d are free. Yes you can use d, just note that holding d and hold left mouse button in UV editor makes annotation and will trigger the display unless you go to preferences, then keymap, then expand window section of keymap list, scroll to bottom of list to the context toggle and expand it, next to the d where it says press change that to click. This way you can do annotations without it toggling the display. Also the display stretch type can be assigned to a hotkey, but not to the quick favorites.
    Just incase you want to use different hotkey here’s my secret: Blender comes with an addon called “Is Key Free”. Enable it then goto the text editor. you can open side bar with ctrl+T or view menu. Then click dev tab. Type in the key or if it’s a key like home, greater than or a numpad key you can click the drop-down below the key input field. Then click magnifying glass icon. If you click list all it will give you a text file with all the default keymaps. I did this for the D key. Then saw there weren’t any for image, uv or paint.
