Forum Archive › Is there a benefit of using a Boolean cut with flipped normals on the cutting cube? › Reply To: Is there a benefit of using a Boolean cut with flipped normals on the cutting cube?
No I don’t think there’s a benefit other than not having to switch the boolean modifier’s settings. At the time I was probably less versed with boolean operations. Setting to difference instead has to be the more straight-forward method 😅
