The fresnel node dynamically affects a mix shader’s factor value. It’s not a constant value; it’s variable across the surface of your model. If you plug in your fresnel value into an emission node (to see the raw color value visualized) you can see the black-to-white values that dynamically affect the factor. Where black values means a factor of 0 and white means a factor of 1; any greys in between mean values between 0 and 1 for the factor.
