No this isn’t the only way. As already pointed out there’s knife projected. You can also do circle as separate objects then give them thickness and use a Boolean modifier. This can lead to some clean up. There’s instancing on faces/vertices method. There is also the tissue addon that comes with blender. You can also build it using geometry nodes. In this video he goes for the method that is easy and has the most consistent outcome.
