@jasonbadum In a lot of case you can right click the menu option and then click assign shortcut. This is one of the times where the option doesn’t work. At least not in newer versions of blender. Technically it does work, but it adds it to the window or system section and so the hotkey never triggers the even, because of the order in which the hotkeys go thru the section. It ends up getting captured at a different section. That’s why you have to manually add it to the user interface section.
