Reply To: Is it possible to set a key bind for insert single keyframe on hover like the default i key bind works?
Forum Archive Is it possible to set a key bind for insert single keyframe on hover like the default i key bind works? Reply To: Is it possible to set a key bind for insert single keyframe on hover like the default i key bind works?
#94615
jason b
    If I recall correctly, Jonathan Lampell also had a shortcut for adding a hotkey in the Press Play course. I wish I could remember how he did it.
