Forum Archive › Is it possible to put a Procedural texture on a specific place? › Reply To: Is it possible to put a Procedural texture on a specific place?
@galledark You need to invert the color inputs and use the Fac output of your attribute. Also, try using a color ramp to fine tune the transition between the color. It worked fine for me at least , see below 🙂
Hope that helps!
