Reply To: Is it normal for such a simple shader to take a while to render? What’s going wrong?
Forum Archive Is it normal for such a simple shader to take a while to render? What’s going wrong? Reply To: Is it normal for such a simple shader to take a while to render? What’s going wrong?
#91568
Dwayne Savage
    Make sure you are set to use GPU and not CPU. Also reduce the number of samples or newer blender versions have a noise threshold setting and a max time setting. Another thing is denoising which allows you to use even less samples, but it’s a balancing act. Blurry vs noise.
