Forum Archive › Is it a good idea to create normal maps in Substance Painter? › Reply To: Is it a good idea to create normal maps in Substance Painter?
That process sounds like it would work well! Skipping the high poly and painting AO in Substance can definitely work if you’re confident that the low poly mesh is exactly what you need.
I’m looking forward to seeing your result!
