pretty much moved to 2.8. however, should I need to do some production work on past projects if they need something still, i’d propably use 2.79 since all the files on those are from that era, and converting them to 2.8 could be time consuming.
though 2.8 is really close, so all the new stuff i’m working, i’m using it, to get more used to it and also relearn my spine to do things differently than i did in 2.79.
also bugs and crashes, you are right about them, however the current beta is really stable (using hardops,boxcutter,decalmachine). though, save often is good habit to have anyway, and save different versions on your projects incase the file gets corrupted for what ever reasons.
if anything on its current state, i find the subdivision modifier laggin the viewport alot, and i have a beefy comp and don’t have that problem in 2.79. though in my case i don’t use it that much, so its not buggin me that much currently.
happy blendering. 🙂
