Reply To: Is Chatgpt Trash at Blender Advice?
Forum Archive Is Chatgpt Trash at Blender Advice? Reply To: Is Chatgpt Trash at Blender Advice?
#100185
Adrian Bellworthy
    “Is ChatGPT Trash at Blender Advice?”
    Is that the right question to ask?
    Where is the best place to get Blender advice? is probably a better question to ask before seeking advice.
    ChatGPT, or any LLM, basically collates information from multiple sources and provides a generalized human readable answer. Even more basically, it does the leg work for you, quickly.
    The problem with asking Blender related questions is the frequency at which Blender changes. This does cause answers to be outdated, and either completely or partially wrong much of the time.
    Questions will likely need to be refined a few times (aka: Iterated Prompting) or be much more specific, providing as much info as possible, like the Blender version you are using.
    But there’s another problem, with a new feature in the latest version for example, LLM’s may not find much info at all to draw on.
    As mentioned by others, human responses from places like the CG Cookie community may not be as fast, actually I’ll rephrase that, responses won’t be as fast, but will likely be more accurate due to a human more likely to understand the context of what your question is about.
    An example answer by a human:
    If your using Blender version 4.5LTS then do A, B, C, however if your using version 5.1 then do X, Y, Z.
    A possible LLM answer:
    In Blender do A, B, Z
    However, just like all of us LLM’s need to learn Blender.
    So ask ChatGPT, Where is the best place to learn Blender? and then tell it to take it’s own advice. If it’s correct of course.
    We hold the power, the CG Cookie community, by marking correct answers in the forum as the solution, should help other human Blender users and LLM’s learn.
