Reply To: irradiance volume (irradiance size, turn on/off)
Forum Archive irradiance volume (irradiance size, turn on/off) Reply To: irradiance volume (irradiance size, turn on/off)
#73973
Adrian Bellworthy
    Hey @senyr,
    Unfortunately your image is not visible, try adding it again below.
    Click the add image tool, then click browse, find the the image in the file browser, double click or drag and drop into the box. Then hover over the image when it appears below, a + will appear, click to use the image.
    You should see the dots as soon as you add the irradiance volume.
    Make sure the irradiance volume object is selected in the viewport.
    When you change the x, y and z values to 1 in the object data properties, there is only one dot in the centre, its not very easy to see.
