Reply To: Inverting multiple values on the graph editor
Forum Archive Inverting multiple values on the graph editor Reply To: Inverting multiple values on the graph editor
#26537
Wayne Dixon
    I’m not sure what you mean Jacob.
    You can scale around the 2d cursor in the GE.  In a similar way to the 3d view.
    But it should not just change rotational direction.  Unless you are doing something weird that gives you gimbal lock, or if you are rotating the parent 180 degrees by accident (then the same rotation will appear different in world space but by the same in local space)
