Reply To: Instead of using the vertex for TEXT can the actual TEXT object be used?
Forum Archive Instead of using the vertex for TEXT can the actual TEXT object be used? Reply To: Instead of using the vertex for TEXT can the actual TEXT object be used?
#60865
arsenhere
    Definetly. it might not look as good though as with the vertices you can line it up with the web a bit.
