Reply To: Individual sizing and values for the multiple objects
Forum Archive Individual sizing and values for the multiple objects Reply To: Individual sizing and values for the multiple objects
#86294
    Hi Enes,
    You are making one Object here (everything up till and including the Volume to Mesh Node) and then Instance that on the Points of the Cube.
    The Random Value Node gives a single random Value in the W of the Noise Texture, but it’s still only one Object that is being Instanced.
    You can randomize the Rotation and Scale of the Instances, but each Instance is still the same Object.
    This is why it  isn’t working, the way you have set this up.
