Forum Archive › In making of columnn where cube and cylinder need to be single mesh › Reply To: In making of columnn where cube and cylinder need to be single mesh
Oh, and when that was what happened, you should select everything in Edit Mode and run the M > Merge by Distance command, because you probably, by trying to Fill, made some extra Vertices on top of the others and that will cause problems!
