Reply To: In 3:18, If you are using Blender 2.75, hit Ctrl-Shift-LMouse won't connect the Fresnel Node to the output, and if you wan…
Forum Archive In 3:18, If you are using Blender 2.75, hit Ctrl-Shift-LMouse won't connect the Fresnel Node to the output, and if you wan… Reply To: In 3:18, If you are using Blender 2.75, hit Ctrl-Shift-LMouse won't connect the Fresnel Node to the output, and if you wan…
#22361
    CTRL + SHIFT + LMB is a function of the “Node Wrangler” addon. Make sure that’s enabled in User Preferences > Addons > Search: Node Wrangler.
