Reply To: I'm not sure I get why you plugged the normal map on all the BSDF materials. Since the purpose is to make the metal look l…
Forum Archive I'm not sure I get why you plugged the normal map on all the BSDF materials. Since the purpose is to make the metal look l… Reply To: I'm not sure I get why you plugged the normal map on all the BSDF materials. Since the purpose is to make the metal look l…
#22422
    It sounds like your head is in the right place, in that adding the normal maps on specific layers only can have a desired effect, like a dust bump map only on the clear-coat layer would make sense.
    But I don’t understand what you mean by “How come they don’t both appear on the same level if they have the same normal map?”
