Reply To: Im not being able to select any vertices, edges or faces
Forum Archive Im not being able to select any vertices, edges or faces Reply To: Im not being able to select any vertices, edges or faces
#80530
    Thanks for sharing the video Sana. It may be what Martin says. Also I see in the outliner you have the reference image selected. Make sure you only selected the mesh and then go into edit mode.
