Reply To: im having troubles with this one pls can you do a video about it
Forum Archive im having troubles with this one pls can you do a video about it Reply To: im having troubles with this one pls can you do a video about it
#70019
Adrian Bellworthy
    Hey @tobe2008 , each of the dots on the motion path is a frame, if you want more space between frames, (faster motion), you can move the keyframes over in the timeline, which will give larger (or smaller) spacing. To adjust the spacing to get progressively larger or smaller between keyframes, you need to rotate the curve handles in the graph editor.
    When ever you make a change, remember to click ‘update paths’ in the properties panel under motion paths.
