Forum Archive › I'm having trouble dragging multiple nodes at once to put in the fame node. I can multiple select, but the second I try to… › Reply To: I'm having trouble dragging multiple nodes at once to put in the fame node. I can multiple select, but the second I try to…
I was having this issue as well. I found that you can use the g key when they are all selected to move all at once.
